D2G Detail: 1999 BMW M3 w/WG Fuzion Heavy Pics
Discussion in 'Show and Shine' started by Dust2Glory, Apr 3, 2008.
  1. Dust2Glory
    Dust2Glory Nuba Guru
    Ok well after 2 days of working on this car I'm finally done... so here is the write up and I hope you enjoy.
    Oh yeah, BTW I need a rotary!!! This car kicked my butt... not 100%, there were some deep scratches that I could not get out, even after wet-sanding with 2000 grit. I love my flex, but this summer I'm gonna have to suck it up and learn what I fear the most.
    Engine:
    Rinsed off, the used RL degreaser... let sit for a couple of mins the agitated with a brush. Rinsed and agitated one more time, let dwell for a couple more mins and did a final rinse.
    I then used compressed air to blow out excess water.
    Did one coat of RL engine dressing... waited a 20-30 mins then followed up w/a coat of CD-2
    Rims/Tires/Wells:
    Rims were rinsed off, then treated w/Meg's Wheel Brite and agitated with a sponge and rinsed off. They got a QD wipe down and to get in btwn the smaller spokes. And a final coat of AW.
    Tires were cleaned w/Awesome APC, agitated w/black schmitt. They got a coat of DP Tire gel, after it cured for hours, I put on a 2nd coat of D2G dressing.
    Wells cleaned w/Awesome APC and dressed w/Fade2Black
    Wash Process:
    Rinsed off and then foamed w/Vroom foam gun. In the bucket I had Wash and Gloss with sponge. After car was washed and rinsed it was foamed up again and clayed w/Riccardo clay. Rinsed, foamed and washed one more time. For drying the car was sprayed down w/QD and dried w/WW drying towels.
    Paint Correction:
    There were some scratches on the trunk the customer wanted to know if I could get out... so I wet-sanded w/2000 grit, didn't even budge the scratches. Oh well.
    I did 1-2 passes of Menz. PG via Flex and LC purple foamed wool pad.
    1-2 passes of Menz. SIP via Flex and 5.5-6.5" LC yellow CCS pad
    1 pass of System 1 via flex and white 6.5" Cobra flex groove, all were done with speed 6, except last pass of S1 went from 4-6-4.
    After all the polishing, I did what I didn't want to do, I drove the car back out of the garage and re-washed it!!!!
    Interior:
    I took before pics but forgot to take after pics!!!!:dupe:
    Vaccuumed out the interior. Did my Meg's APC wipe down, then cleaned the leather w/CG leather cleaner+ w/meg's interior brush.
    Treated w/CG Silk shine and leather got RL leather conditioner... Vents got F2B.
    Treated carpet and floor mats w/Lightening:Folex mix and did hot water extraction. Dried and odor neutralizer.
    LSP:
    Before I applied Fuzion I used Lusso Oro Creme via Flex and a black CCS pad to ensure I had a really clean surface to work with.
    I ended up doing two coats of Fuzion... I was going to top Fuzion with Souveran but decided against it!!!
    First night I did a coat using body line motions, buffed off. When I came out the next day I did a light QD wipe down to remove the dust. On the 2nd application of Fuzion I did the wax-on motion. Buffed off with a Trop-care plush MF ( I LOVE THESE THINGS)
    Others:
    Polished out the pipes(No pics:sorry:), grill and license plate frame w/Master Formula
    All trim dressed w/VRP
    Black honey comb grill got F2B
    Windows SIG
    3M green tape to tape off vehicle
    Will show before pics, durings and then the afters!!!
    P.S.- Fuzion is a great wax to work with. Give alot of clarity and shine to the vehicle, it lacks the depth of Souveran... but makes up for that in what should be durability. It's also forgiving if you let it set... I let it set for 30mins both applications and was as easy to rub off than a fresh coat of souveran. Little harder if you over apply wax to one certain spot... but we all know THIN IS IN. I don't know when I'll see this car again, found out today it only gets driven 4 times a month or so. I wouldn't rate this better than Souveran just because Souveran is a "Show" was and Fuzion is for lasting protection.
    What I was up against:
    Pics of the truck before wet-sanding:
    After Sanding:
    After polishing out:
    Before hood:
    After hood:
    Before rear panel:
    After rear panel:
    This is what it looked like after applying wax, but before buffing off:
    Finally.... THE AFTERS!!!!
  2. P1et
    Looking really good, looks like you put quite a bit of time into that thing!!!
  3. mixxer
    mixxer Birth of a Detailer
    You did a great job ! Im not to impressed with the fuzion,ive seen nicer waxes on black.
  4. cwcad
    cwcad Birth of a Detailer
    I did an M3 like that several years ago. Even with a rotary it is hard to clear the paint up. I think that you did a fine job with your Flex.
  5. GBS
    GBS Wax on..Wax off
    Very nice D2G. That engine looks like new. It's missing one of your great interior details.
  6. Smith2287
    Great work dust, it looks like a lot of man hours went into that car.:applause:
  7. JLs Detailing
    Wow a lot of work went into that one didn't it! I would have loved to have seen you put some Rubbish Boys on that though! Bet that would have been awesome.
  8. RCSBeast
    RCSBeast Virgin Detailer
    He actually did the interior (which M-series interiors are awesome!) but not sure why he didn't take/post up pics.. :shead:
  9. ampbmw
    ampbmw DB Forum Supporter
    black wow on the trim please!
    haha j/k bro that looks insane! too bad the trunk had that one rid...otherwise the car looks flawless after your magic!
    what products though?
  10. pirex
    pirex DB Certified Dealer
    SWEET work Dust!! Love it :D
  11. Scott's Mobile Detailing
    looks like crap......bahaha jk man, that thing looks good, nice correction :)
  12. Dust2Glory
    come to find out, this actually had alot of flake in the paint, so it wasn't a true black... NTL thanks
    Thanks CWCAD, I don't hardly ever cuss... but I wanted to cuss this car up and down two ways to tuesday!! I still think a rotary would help.
    Gary I did an interior detail and took before shots, but as mentioned I was an idiot and forgot the afters which look really good. but oh well, what can you do
    ALOT of time, but I got paid $385 plus tip so i wasn't crying that much!!
    :thumb:
    Yeah yeah, rub it in JL... thanks. As soon as my business tax return gets here.... Rubbish boys here I come!!!
    Shut up clayton
    the VRP did ok... before i worked on the vehicle, there was ALOT of staining on the trim from I guess previous polishing or wax application. I probably could of cleaned it with some alcohol but didn't wanna risk touching the paint. Would black wow cover that stuff up?
    Thanks brother from across the ocean!!!!
  13. Dust2Glory
    Thanks alot Scott!!!:catfight: I'm gonna get a really crappy one when you decide to come down
  14. LanceM
    LanceM DB Forum Supporter
    great correction. especially the sanding
  15. Tonya
    Tonya Welcome to Detailing
    WOW D2G nice job! Wetsanding was impressive! Great job in the engine too!
  16. tdekany
    tdekany Wax on..Wax off
    What a fantastic detail!
