Cleaning Windows
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Solidsnake, May 20, 2009.
  1. Solidsnake
    Solidsnake Jedi Nuba
    The way I've been taught to clean windows is spray it with windex, wipe it with a sheep-skin shammy then go over it with a microfiber.
    Is there any other (better) way to do it because sometimes there are a few smudges that I end up noticing after I've finished detailing my car. Also, are there any other window products that are good or better than windex? I have Invisible Glass which is a foamy spray but I've never tried it on a car. Any help would be nice. Thanks.
  2. billyblooshoes
    Stoners invisible glass is one of the best out there in my opinion. Check out detailers domain and pick yourself up some of his uber glass towels and you won't have to worry about those stray streaks anymore.
  3. d00t
    d00t Welcome to Detailing
    Stoners invisible glass, w/DD glass towel. Then follow it up with DI/Distilled water and another glass towel. No streaks :).
    Lately, I've just been polishing windows, and then a DI wipe down, instead of just cleaning them wit Invisible Glass though.
  4. krshultz
    krshultz Nuba Guru
    I just tried Sprayway for the first time this afternoon. Good stuff. A little cheaper than IG, and it smells good. I finally found it at Target, in the household cleaning products section.
  5. supercharged
    I clean my glass with Surf City Garage Clearly Better, or Eimann Fabrik Clear Vision II Glass Cleaner. I gotta admit, I like both. Eimann Fabric looks like water, it's clear and has no scent to it...and no streaks!
  6. 911Fanatic
    If you do your windows regularly, a pair of clean WW window towels and plain water will do it. Other than that, an alcohol based window cleaner and WW window towels. The trick with glass is to keep your towel dry. As soon as it becomes damp all over, its done. Grab a fresh one.
  7. Denzil
    How much are they ringing up for there Karl?
    I agree with this but I've only been using this technique with regular MF and glass MF towels. I guess I'll have to try the WW route.
  8. Erik Mejia
    Erik Mejia Obsessive Detailer
    Meguiar's Professional Glass Cleaner (Dilutes 10:1) IMHO is one of the best glass cleaner out there. Combine this with a soft, nappy 100% cotton towel and you will get streak free results every time.:thumb:
    On the plus side the towel doesn't leave those tiny fibers (only visible in certain lighting) that some microfibers leave behind.
  9. Al-53
    Al-53 Welcome to Detailing
    Another good glass cleaner is ZEP professional Glass Cleaner..it is the Green stuff...1oz to 31oz of water...stuff cleans great..tint safe....nice smell....1 gallon makes 32 gallons of cleaner..and best part it is under 10.00 a gallon for the concentrate.....
    now it is the green stuff..not the blue..that contains ammonia....GREEN.....try it...be surprised....it is posted on here from others who tried it and liked it very well for the streak free cleaning..
    PS..it can be used as a multi surface cleaner also....I use it on plastics also...
    Al
  10. sal329
    sal329 Nuba Guru
    Im with Al, the Zep glass cleaner is great, I use that Surf City or FK 228 (once I run out of the SC and FK I will stick to just Zep it is so economical). I spray the window, wipe with a window towel then follow up with a WW I got from Walmart kitchenware
  11. krshultz
    krshultz Nuba Guru
    $2.59 for a 19 ounce can. I think I may have found my new glass cleaner :headbang:
  12. Pats300zx
    I agree with Al on the Zep. I love this stuff and have been using it for over a year. Thanks to Al it's my go to glass cleaner :)
  13. dschia
    dschia Jedi Nuba
    I seldom get smudges if I buffed the window last with a dry WW. For window that is in a bad state, usually I do a quick claying after i clayed the veh.. However, window cleaning is still something i feared most because i couldn't avoid not linting it with my WW after i washed it. :thud:
  14. krshultz
    krshultz Nuba Guru
    Alright, since we're talking about glass cleaning...here's one.
    Really difficult to remove haze on the *inside* of the windshield of my F250. Looks like the sort of haze you'd expect from a smoker's vehicle, but it doesn't smell like smoke. And this stuff is STUBBORN. Mostly, I seem to just move it around...but I can't quite make it go away. It's getting annoying. Stoner's IG, Sprayway, neither one of them are working.
    Tried white vinegar. In addition to making the inside of the truck smell like vinegar, it didn't work. Haven't considered clay, because it's on the inside, and that sounds a bit messy, but...maybe that's the next thing I should try.
    Man, someone who had this thing before me really treated it badly. :shead:
  15. Hostage1978
    Hostage1978 Guest
    Sprayway is great
    Swisswax is great
    ONR is great at regular mix dilution
    I'm thinking it's more technique than product. As mentioned, a WW or two really helps out on the procedure.
  16. Denzil
    Hmm, wonder what residue that is that you're dealing with. Have you tried IPA already?
  17. krshultz
    krshultz Nuba Guru
    I haven't. I'll try that tomorrow, that's a great idea.
  18. Dale
    Dale Any Rag Vehicle Washer
    What is WW???
  19. richy
    Karl..have you got a steamer? Have you tried hitting it with steam?
  20. Nica
    If I'm not mistaken:
    WW = Waffle Weaved
