cleaning tires
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by cleanfiend, Apr 16, 2010.
  1. cleanfiend
    cleanfiend Jedi Nuba
    what do you guys use to clean tires? these are the hardest things for me to get totally clean. I usually have to do 2 or 3 rounds of meg's apc scrub downs and even then sometimes they arent totally clean.
    if you guys could share what products you like to use and/or any tips, that would be great.
  2. RustyBumper
    RustyBumper Jedi Nuba
    I've found Power Clean to work pretty well for me. Only downside is the cost of it.
  3. mrgolfrider
    Zep citrus 1:1 worked great for me today, at its cheap at 10 bucks a gallon.
  4. Emile
    Emile Welcome to Detailing
    Meguiar's APC is a great product, but for whatever reason, it isn't the greatest product at cleaning tires.
    Better to turn to Meg's Super Degreaser for a job like tires.
    Personally, I usually use whatever wheel cleaner I am using and a medium-stiffness brush.
    Sometimes if I know the tire is dirty, I will spray the wheel cleaner on the tires, let it dwell for a minute or two, rinse off, then start again but using a brush the second time around. It helps even more if the brush is dwelling in a bucket of car wash soap.
    -Almost forgot, don't confuse a tire's bulit-in wax protection with dirt. When I am applying tire shine to my father's car, no matter how clean I get the tires, once I am done, my applicator is completely black by then.
  5. richy
    Zep Citrus or if they're really nasty, Zep purple at 4;1. scrub with a good brush too.
  6. slanguage
    grime reaper at 3:1
  7. rwisejr
    rwisejr DB Forum Supporter
    +1 for Zep Citrus
  8. Tjfrom215
    Tjfrom215 Birth of a Detailer
    I use Zep Citrus or P21S Total Auto Wash,
    either one I let sit for a bit and scrub in with a stiff brush.
  9. lifemal
    lifemal Wax on..Wax off
    I use Autoglym Custom Wheel Cleaner! It's fantastic on tires AND wheels.
  10. supercharged
    Megs Super Degreaser @ 4:1. I saw Clark using it, and gave it a try and been using it ever since...does it's job well, and pretty cost effective too.
  11. 911Fanatic
    +1. AG CWC will pull more dirt out of your tires than anything else.
  12. roastpuff
    roastpuff Virgin Detailer
    I can attest to that. I had "new" tires that were dirty from being stored unwashed, and CWC cleaned them up good!
  13. Berscht
    Berscht Jedi Nuba
    +3 on AG CWC. Ken is right, nothing pulls out more grime than this stuff.
  14. cleanfiend
    i have a question about AG CWC. the description of the product states that it dissolves brake dust, so does this stuff work similar to sonax full effect in that it actually dissolves the brake dust and makes it easy to rinse away, or is it more like p21s in the way that it cleans?
  15. stottie
    stottie Birth of a Detailer
    i also use zep citrus for tires, since it is cheap like said but works well. But for dirty tires or if im in a hurry i use detail king tire and whitewall cleaner, this product releases so much gunk from the tires its unreal. plus it has a darking agent witch leaves the wheels nice and not browing.
  16. vtec92civic
    vtec92civic Nuba Guru
    i need to try the zep citrus and see how that works on tires. Right now i am using westley's bleach white and that stuff really works but if i can use a citrus cleaner which will be a little more bang for the buck and be safer i'll go with that . . . . .
    so far though the cleaning power of bleach white has been un-touchable.
  17. 02blackout
    02blackout DB Forum Supporter
    Dont use Sonax Full Effect on your tires dude lol. Not sure if tires can be damaged from chemicals but just not worth using a product of that value on tires.
    I use Megs APC 4:1 and scrub them with my wheel well brush. Once the gallon is done I'm going to Power Clean or something.
