Clay lube vs soap & water
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by TONY MONTANA, Dec 30, 2009.
  1. TONY MONTANA
    ive seen people on here use water with soap as a clay lube and i was wondering how it stacks up against a regular qd clay lube is it better or just as good? also how much soap do you add to the water? thanks
  2. 911Fanatic
    You can use soap and water, but typically it will cause the clay to break down prematurely. If you are the kind of guy who uses the piece one time and bins it, then have it. If you like to use it one more than one car, I'd suggest a proper clay lube.
  3. As 911 stated, the water will degrade the clay. Using a dedicated clay lube is the best way to go if you plan on using your clay more than once. A great economical clay lube is ONR diluted. :)
  4. Strokin04
    Strokin04 Birth of a Detailer
    +1 for ONR!!! I haven't used anything else for clay lube since I started using ONR.
  5. TONY MONTANA
    will ONR deteriorate clay at all?
  6. blackjz
    blackjz Jedi Nuba
    not with me...as long as you use correction dilution ration....
  7. Strokin04
    Has not hurt any of my clay.
  8. Esienmann_M6
    Esienmann_M6 Two Bucket System Washer
    I had issues with ONR as a clay lube in the past, it tends to marr the paint with sonus green fine clay
    and requires a polish afterwords. something must be wrong although I am sure I have enough ONR
    in the pressure sprayer more than required for a QD ratio. will try both "ONR and soap/water" on Friday and report back.
  9. Interesting. You should always polish after claying anyways because even with the correct dilution, claying will leave behind some marring. You can check the ONR product page and it will tell you the correct ratios to use for wash, QD, and clay lube. Give that a shot and you should see less marring. :)
  10. Berscht
    Berscht Jedi Nuba
    I always just use soap and water as a my clay lube. I use just a small amount at the bottom of a spray bottle and the rest water. What 911 stated is true but clay simply just does not last long enough for me to care if it deteriorates over time.
  11. Carn
    Carn Welcome to Detailing
    I normally uses a soap solution but then again I also usually cut my clay into small pieces and turf them after each vehicle :thumb:
  12. togwt
    +1 for ONR -2oz / gallon
  13. Bunky
    Bunky Guest
    I would not take a chance. I use Meg's Quick Detailer but would reach for another detailing when I run out. I have heard too many comments about negative experiences using ONR so I will skip that.
  14. supercharged
    I usually make clay lube of my own - 2 oz of ONR and about 1/2 oz Megs #00 High Tech Wash, which makes clay solution very slippery, and never degraded any of my clay bars...
  15. Esienmann_M6
    ONR played nicely today, no marring from claying I heated the clay in a bucket of water so
    that might have helped! 13 hours so far and looks like an all nigher! back to the garage :crasy:
