CG Fabric Clean Dillutions?
Discussion in 'Interior Car Care' started by Emile, Jan 7, 2010.
  1. Emile
    Emile Welcome to Detailing
    Hi,
    I just ordered two 16oz bottles of Fabric Clean. Detailed Image says to dilute up to 8:1 and the bottle says to go "20:1 or as desired." The concentrate formula is extrmely thick so I did 20:1 and it seems to work alright.
    What dilution ratios are you guys using? Should I only use 20:1 or should I have two bottles, one for 20:1 for maintenance cleaning and a stronger dilution for spot-cleaning? Any suggestions for stronger cleaning?
    Thanks,
    Emile
  2. Emile
    Nobody else uses this product? Is something wrong with it?
  3. anbuzero
    anbuzero DB Pro Supporter
    5:1 gets almost everything out
  4. advs1
    advs1 DB Forum Supporter
    i usually use it 4:1
  5. MWAUTOPRO
    MWAUTOPRO Jedi Nuba
    20:1 is what we use in our shop - it is our go-to shampoo
  6. pektel
    pektel DB Forum Supporter
    bump. I just ordered a 16 oz of this as well. Hopefully it works well. Anyone else with experience with it?
  7. Dr. Bob
    Dr. Bob Birth of a Detailer
    Cleaning Old And Stubborn Stains:
    Always test fabric/fiber for color fastness in an inconspicuous area
    Dilute according to desired needs ( approximately 20:1 or as needed)
    Apply to stained area. Allow to penetrate 10-60 seconds. Blot with a clean absorbent cloth
    In a matter of seconds the specially formulated cleaning agents emulsify the stain and the while the surfactants to unlock the soil from the fabric and suspend the dirt in the liquid
    When you blot with a clean dry cloth, the liquid containing the stain transfers to the cloth.
    Re-apply as needed, depending of desired cleaning needs.
    From CG website.
