This is my first write-up here. This car is a 2001 Audi RS4 with MTM Chip, exhaust and wheels. It belongs to a member of my family, and I got to drive it after I finished it Car at arrival: First I sprayed the car down: Then it was on to the wheels. I diluted Bilberry 1:3: Sprayed on, then left to cure: Then I attacked the wheels with a Swissvax Wheel Brush and a Vikan brush: The tires received a coat of ARO and a scrub with Meguiar's Tire Brush: Which left this: Then sprayed off: Went over the car with ARO and a Swissvax Detail Brush: Then i washed the car with CG Citruswash + Gloss: Claying with Riccardo Clay and Meguiar's Last Touch as lube: I also clayed the wheels: Then i washed the car again, and dried it with the Dehydrator Drying Towel: Then it was into the garage for inspection: After some testing, I settled with Scholl S30+ and S3+ on a Scholl medium 5” pad: During: Some bad 50/50’s: Rear lights before/after: Then i went over the car with Last Touch and a Ultra Plush MF to remove polishing dust: Then i layed on a coat with Duragloss 501: Exhaust and alu polished with Meguiar's All Metal Polysh: Trim got some CG New Look Trim Gel: Glass cleaned with Diamondite Perfect Vision Glass Cleaner: Then i buffed off DG 501: Then on to the rims: They also recieved a coat of DG 501: Tires got P21S Reifen Glanz: Wheel wells and other plastics got CG Bare Bones: Then i wiped off DG 501 from the wheels: The car got a coat of DG 111 the day after: And buffed off after 20 min: Hoovered the interior: And washed it with DP Total Interior Cleaner: Then a coat of Optimum Protectant: Leather got Pinnacle Leather Conditioner: All carbon I polished with Lusso Revitalizing Creme: The engine was not so filthy, so i wiped it off with last touch: Results: Total time spent: 23 hours
Excellent work on a fantastic motor car......That is still one of the sexiest RS models Audi has built to date !
That looks amazing, I most certainly enjoy using Duragloss products and I'm glad to see others are seeing results as I am... GREAT WORK!
Sigh , Makes me wish I had my S4 again... Always wished we could have had the K04 powered Touring's brought to Canada.. oh well.. Brilliant Work!!
