I worked Tough Prep on a rotary with a yellow 3M pad only working it between 1000-1200 working panel by panel, I am really impressed with the results so some befores: The car was washed with AF Lather then detared and iron removed before claying car was dried then put inside for the Tough Prep, you can see some 50/50 shots Before: After: Also going over the lights it did sharpen them up Some Mercury now some afters, after TC has been applied Now for some outside Thanks for looking
How much tough prep was applied to the pad while buffing, asI to have tough prep and looking forward to using even more now
Thanks Guys, Alex I primed the pad first with a cross for the very first set, then all is required for the next set and there after is two pea size blobs, after a couple of panels I was cleaning the pad to keep it in good condition.
Not something I have tried with tough prep, but as tough prep is designed for sealants and doesn't leave any fillers and glazing oils behind I think it would make a good base for most sealants.
