Aston Martin DB9.
Discussion in 'Professional Detailer's Studio' started by Clark, Feb 1, 2009.
  1. Clark
    Clark Two Bucket System Washer
    This was the second detail of the week after completing a minor correction on a 997 C4S on Monday and Tues :)
    Car:
    Service Option: 3 day Major Paint Correction Detail.
    The owner had travelled all the way up from Glasgow so it was no real surprise to find the car was quite grubby upon its arrival, so an extra generous helping of APC in the foam lance (60 degrees) was used to try and remove as much dirt and grime as possible:
    This was left to dwell for 5 minutes before foaming again and then rinsing at high pressure (again at 60 degrees):
    The hot water pressure washer comes into its own in these times - not much dirt left on the paint now :)
    The wheels and tyres were cleaned with Blackfire's wheel and tyre cleaner (menzerna 7.5 replacement), then Autosmart Tardis followed by Megs Super degreaser in the arches:
    The engine bay was rinsed at medium pressure after being soaked with Super degreaser:
    All the exterior trim and shuts were cleaned with APC and a slide lock brush before I then washed the car with the 2BM and Meguiars Shampoo Plus:
    Tardis was used again to remove some minor tar spots along the lower half of the car and arch lips and I then put the car inside for claying.
    Meguiars Quick Clay was used as there wasn’t a huge amount of contamination present as you can see from the (out of focus :eek:) pic:
    Once dried off I took paint readings which showed everything on the car was original except for an area on the o/s rear quarter which had been blown in. The paint readings were anything from 65 to 150 microns but the composite gauge was able to split the layers nicely and I found that I still had decent (and safe) levels of clear to play with even on the low areas.
    Now time to inspect the paintwork...
    buffer trails:
    Micro marring from a sanding disc used by machine:
    More micro marring:
    And here you can see where the rear arch has been blown in:
    So overall the paint was in a pretty poor state of affairs, with pretty much every panel showing signs of sanding haze not properly polished out and some areas not even polished at all. As the paint was all original I can only assume this was due to the prep done by Aston Martin themselves as I have seen similair examples on various detailing forums before and have heard of new car prep problems of this sort...
    Correction:
    After a quick play about with polish and pad combinations I settled on a mix of Menzerna 3.02 and 3M Fast Cut Plus with a Meguiars Cutting Pad:
    This achieved the desired result with some areas needing 2 hits:
    The smaller areas were cut in with 4" and 3.5" pads throughout the detail:
    Some more correction shots in no particular order:
    Before:
    After:
    Rear quarter which had been blown in:
    50/50:
    completed:
    50/50 on top of rear quarter:
    Before:
    After:
    Before:
    After:
    This 50/50 shows how much clarity you lose in the paint from all the micro marring:
    The lower lips on the doors were done with the smaller pads:
    Before:
    After:
    Before:
    After:
    The back bumper took a bit of extra effort where the worst of the micro marring was:
    Before:
    After:
    Top of back bumper before:
    After:
    Before:
    After:
    Once all the correction work was completed I then refined the paint further with Menzerna PO85 RE5 and a Meguiars finishing pad. This stage alone took well over 7 hours to do properly.
    The flake really started to show through the nicely prepped surface though...
    A lambs wool duster was used to remove all traces of polishing dust and the paint was then given a thorough wipe down with Top Inspection to remove any remaining oils.
    A classy car needs a classy wax so Vintage was applied by applicator pad to the whole car and then buffed off after 10 minutes, meanwhile Marsha had sealed the wheels (Blackfire Metal Sealant), dressed the tyres (Gloss-It) and polished the tailpipes (Megs NXT).
    This was the interior process:
    - Thoroughly hoovered
    - APC wipe down
    - Glass cleaned with Eimann Fabrik
    - Leather fed with Raceglaze Leather Balm
    - Shuts waxed with Vintage
    The engine was dressed with Aerospace 303 and the underside of the bonnet was wiped down with Gloss-It QD:
    And here are the obligatory Sun Gun shots to show the final finish. I should point out that these were taken before the final wipe down so there are some smears from the Vintage in a couple of the pics :)
    And here's the ones Rich took with his SLR :)
    Total Work Time: 33 Hours.
    Thanks for taking the time to read as always :thumb:
  2. Smith2287
    OMG!!! What attention to detail on this one you really did a amazing job. Your correction was perfect and the car finished off with vintage looks amazing.
  3. Buddy
    Great detail Clark. It came out beautiful. It looks like a brand new car now. I enjoyed the write up as well. Thanks...:thumb:
  4. detaildoc
    detaildoc Guest
    Awesome turnaround! :worship2: That poor Aston was in bad shape.
  5. Brian N
    Brian N Jedi Nuba
    Great Work. Love Astons they always look so beautiful.
  6. P1et
    Super work on a beautiful car.
  7. billyblooshoes
    absolutely gorgeous. the work AND the car.
  8. Denzil
    Looks great Clark! Thanks for sharing.
  9. krshultz
    krshultz Nuba Guru
    Fantastic job! :applause2:
    I doubt I'm alone in thinking that the DB9 may be the most beautiful car ever made.
  10. Nica
    Well done Clark, always blown away by your attention to detail and write ups :worship2: :worship2:
    Love these vehicles, love there shape/curves :thumb:
    Thanks for sharing with us.
  11. FMINUS
    FMINUS DB Pro Supporter
    Great job man!
  12. J BELL
    J BELL Nuba Guru
    Very fond of your work, great job!
  13. er1k
    er1k Obsessive Detailer
    Those reflection shots are incredible. Great work!
  14. yukonon22
    yukonon22 Wax on..Wax off
    great work clark
  15. Detail Company
    Detail Company Any Rag Vehicle Washer
    No words man,
    no words....
    :worship2::picture::worship2::picture:
