Ask: Applying wax without smearing
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by gio, Aug 3, 2009.
  1. gio
    gio Any Rag Vehicle Washer
    Guys, i need your guidance, how to properly waxing a car, cause i can see a bit smear on my car if using Collinite 915, Autoglym HD wax. I already put some QD on my applicator and i tried to apply it as thin as possible. I have tried circular motion and one way motion, but still a bit smear.
    Really appreciate your help.
    Cheers,
    gio
  2. flash gordon
    flash gordon Banned
    Try moistening your applicator pad with water, ring it out good and apply wax. Work in sections.
    Are you doing this by hand or machine?
  3. agpatel
    2x what flash said, dont use a QD, just get the applicator a little damn. I have a misting bottled filled with distilled water and I just spritz it a few times and apply the wax. Try not to load up the applicator with too much product or you could also get smearing.
  4. Solidsnake
    Solidsnake Jedi Nuba
    What I do is take an applicator pad, and take a section/panel on the car. I put some wax on the dry applicator pad and spread the wax around on the surface (I am not applying the wax, I'm just tapping different areas of the panel with it to spread it around). Then I start moving in circular motions but lightly, not applying too much pressure. After applying it, wipe it off with a microfiber and you're good to go.
  5. gio
    Thanks for the input, i will try it again with distilled water. I applying wax by hand. Cause i only have a rotary.
    @solidsnake
    i tried this way before, the result still smear. i applied the wax without any pressure. and always buff it with clean MF.
    I found that HD wax is got more potential smear than 915.
  6. pektel
    pektel DB Forum Supporter
    Try letting the wax cure for a while before removing. The solvents may not have evaporated yet, causing your smearing.
  7. supercharged
    wipe on, wipe right off...don't let it dry.
  8. flash gordon
    flash gordon Banned
    I love this Site....Great minds think alike^^^:giggle:
  9. gio
    Doesn't wax need to haze / dry first before buffing?
  10. SSTG
    SSTG DB Forum Supporter
    Sealants do.
  11. pektel
    just throwing it out there. If the wowo method isn.t working, then try something different. Try the swipe test.
  12. pektel
    i am by no means an expert. But i would guess that humid conditions would slow evaporation of the spreading agents (solvents). I could very well be wrong, just throwing a suggestion out there
  13. flash gordon
    flash gordon Banned
    Your Absolutely right. High Humidity can cause havik on a paint job. :thud:
    This is certainaly something to think of especially when you have had success in the past with a product. and then 1 day it throws you for a loop :sos:
  14. 911Fanatic
    With AG Hi Def wax, LET IT DRY. If you try to apply it and remove it right away it will smear. I've even applied it to an entire F350 before removing it with no issues. Try doing one side at a time. When you can run your finger through it and it doesn't streak it's ready to come off. Call or text me at 604.561.5121 if you have any more issues.
  15. MoeMistry
    MoeMistry Any Rag Vehicle Washer
    Good suggestion...humidity plays a large role when dealing with carnaubas. I don't find this to be an issue with synthetics like 1Z Glanz.
  16. 911Fanatic
    Hey Moe. Nice to see you here. Welcome aboard.
  17. Legacy99
    Legacy99 Wax on..Wax off
    Some do, some don't. Alway's read the label, the manf. knows best.
  18. togwt
    Hi Moe, good to see you shareing your knowledge posting here :applause2:
  19. gio
    yes, i will try any possible option. thanks mate.
    yeah, i think indonesia is a very humid country, i should let dry first, maybe if i applied in the evening, i would buff it next noon.
    thanks for your help mate.
    cheers:thumb:
  20. gio
    Problem Solved...
    Just dampen the applicator with water. smear free.
    Thanks guys...
