Anti Static Products
Discussion in 'Car Detailing Product Discussion' started by FMINUS, Oct 24, 2007.
  1. FMINUS
    FMINUS DB Pro Supporter
    I have been using CG QSD and FK425 which are both supposed to have anti static properties. However I cant really seem to tell the difference between those and normal QDs in terms of dust repllent.
    Anyone ever do a side by side?
    If not, Ill do it on the trunk of my BLACK M5 and check the results! I live in a really dusty area so this should be a no brainer
  2. sneek
    sneek Nuba Guru
    :D:D DO IT!
    I dont think anyone has tried this yet.
  3. Nica
    Sweet...I agree do it...I've been curious about this my self but just haven't gotten around to test it out.
  4. FMINUS
    just sprayed the trunk with
    CG speed detailer (or something like that)
    CG SQD
    FK 425
    post results tommorrow
  5. Nica
    Sweet look forward to the results bro :D
  6. klumzypinoy
    klumzypinoy Nuba Guru
    Someone has tried grounding their vehicle, i forgot how, but the dusting was reduced a lot :p.
  7. FMINUS
    ok after one dusty SOCAL afternoon,
    The QDs rank as follows: (from least to most dust)
    CG Synthetic QD
    CG Speedwipe (non-anti static)
    FK425
    Im going to retry again, as its weird to me that FK425 got beat by an NON anti st.
    And I did use different towels to wipe down each section
  8. FMINUS
    reporting back, same results. FK425 seems to have less antistatic properties than CG's regular QD which is kind of sad.
    CG SQD works the best at repelling dust, but it is still a marginal difference at best
  9. Nica
    That's interesting results there FMINUS...very interesting in deed.
  10. FMINUS
    FK did replace SQD as my favorite QD, but now its back down as second....
    SQD is about 1/2 the price of the FK anyways
  11. Sparkie
    Sparkie Wax on..Wax off
    I do like FK425, for the money I use DG#521 its slicker IMO. I would like to see how it holds to FMINUS test. How about it FMINUS? You got any?
  12. FMINUS
    I dont :(
  13. FMINUS
    BTW WELCOME Sparkie!
  14. Sparkie
    Thanks brother for the welcome!
    If you want to try some PM me your address I will send you some to try!:D
  15. FMINUS
    :righton:
  16. FMINUS
    I just found out that CG speedwipe is AS.... that explains a lot!
  17. D&D Auto Detailing
  18. klumzypinoy
    I believe he meant anti static.
  19. FMINUS
    I got it today!!! THANKS!!!!!!
  20. Al-53
    Al-53 Welcome to Detailing
    I found that DG #521 Marine Detailer to have better anti static properties than FK 425....I did a side by side test on a TV screen..which you all know is a dust collector....the DG side had way less dust after 2 weeks....
    The other product I have found to have great anti static is Lucas Slick Mist....
    AL
