Alternative Uses for nextzett Products
Discussion in 'Car Detailing Product Discussion' started by Michael @ einszett, Jun 3, 2010.
  1. Michael @ einszett
    Michael @ einszett DB Certified Manufacturer
    Here are some nextzett products and their alternative uses that you can use around the house. If you have any other ones, please feel free to share.
    Cockpit Premium
    * Clean computer, cell phones, TVs (except screens with anti-reflective coatings - mainly Plasmas) and other metal, plastic coated surfaces
    * Wipe down clear coated furniture
    * Wipe down metal trim and finished leather trim
    Plastic Deep Cleaner
    * Upholstery/carpet spot remover (do a color fast test first)
    * Headliner spot remover (do a color fast test first)
    * Clean grime, scuff marks, crayons from walls, baseboards, doors
    * Remove stains from cabriolet tops
    * Remove bitumen (tar) from body paint and wheels
    * Remove wax and polish residue from plastic and rubber trim
    * Pre-clean tires prior to applying a rubber treatment for better adhesion and for a more even finish
    Vinyl-Rubber Extra (Improved version of Vinyl-Rubber Care and Protectant
    * Apply on polycanvas tops to reduce fading from UV
    * Apply on outdoor patio furniture to revive color and keep from getting brittle from sun
    * Apply prior to polishing or waxing so any splatter will wipe off easily
    W99
    * Make a degreaser like Formula 409 replacement. 1-2 oz of W99 mixed with 16 oz of distilled water
    Blitz
    * Excellent as a laundry detergent even on sensitive fibers
    No. 2 One Step Polish
    * Remove scratches from CD's and DVD's and other clear plastic surfaces
  2. agpatel
    Great tips there Michael, one thing to be aware the tip below,
    If using on a TV dont use it on TV screen that have AR coatings or it will take it right off like AR coatings on plasma TVs. My understanding is that CP has some alcohols in it which will damage AR coating and on plasma TV the AR coating is very sensitive. LCD panels if a matte screen should be fine but the newer "shiny" screens you will want to be careful of also.
    I will say that w99 makes a great degrease around the house and helped clean up a greasy grill up in no time.
  3. Michael @ einszett
    Thanks for pointing this out! :thumb:
    This is true. When stating this tip, I had LCD screens in mind. Follow manufacturer's advice on cleaning. Generally you are safe with a slightly damp microfiber cloth.
    You are cautioned from even using a mild soap cleaner when wiping down screens with ARC (anti-reflective coating). Definitely stay away from ammonia-based cleaners and other traditional household cleaners that may have aggressive cleaners.
  4. bakchoi
    bakchoi Birth of a Detailer
    would it work for lens on glasses? :shead:
  5. Michael @ einszett
    I'm not an expert in eyeglass lens material but my first instinct would be 'no'. Reason being that if you did use the polish, you would immediately remove any anti-reflective coating and/or UV coating. So I would highly suggest that you don't use it in this case.
    The kind of plastic used for CD's, headlights, guage clusters and windows used on race cars are lexan which is a type of polycarbonate.
    Also, I would not suggest you use the polish on helmet lenses unless the manufacturer states that you can use a polishing abrasive on the surface to smooth out scratches. But if there's any kind of UV coating don't use it. Just a soft cloth and mild cleaner like Windscreen Clear.
  6. dankfanatic
    dankfanatic Guest
    Blitz as a laundry detergent?
    hm...imma have to try that with my mfs.
  7. Michael @ einszett
    Definitely. I've replaced my regular laundry detergent a long time ago. Great, fresh smell too :thumb:
  8. detailersdomain
    great post! I have updated my blog and just about every site we are on ;)
  9. supercharged
    Hey, Michael, why is Plastic Deep Cleaner not available in 10 liter refills anymore? Buying it in small bottles becomes too expensive...
  10. detailersdomain
    you can always hit me up for case qty pricing.
  11. supercharged
    good idea...I don't need any at the moment, but will be interested later on...
  12. Michael @ einszett
    Unfortunately it comes down to lack of demand for the larger size. Well, at least when we had it in stock.
    Anybody else interested in the 10l size of Plastic? Please feel free to let me know here.
  13. Michael @ einszett
    Updated - added a couple of more for Plastic Deep Cleaner and one more for Vinyl-Rubber Care and Protectant.
  14. blas
    blas Birth of a Detailer
    i always clean my white vaio (incluiding the screen) with Cockpit Premium.. awesome product.
  15. bonehead
    bonehead Jedi Nuba
    Can the Plastic Deep Cleaner be used to care for clear bras?
  16. Erik Mejia
    Erik Mejia Obsessive Detailer
    Excellent thread.:applause:
  17. michakaveli
    I was thinking of using my Cockpit Premium to wipre down my LCD display at workt and my screen at home....
    I know Michael posted initially against it, (i.e. plasma, which I wanted to use for also), but curious if the LCD's displays for computers may be adversely affected by Cockpit Premium. I imagine the screen would have some anit-glare coating... but I do not know for sure...
    Anyone tried it before? I thought that you could use CP for navi screens in vehicles....
  18. dankfanatic
    dankfanatic Guest
    i've been using CP on all my LCDs inside the house. works beautifully!
    on a side note, whats a good dilution for 1Z Blitz in a foam cannon?
  19. Michael @ einszett
    Plastic Deep Cleaner on clear bras: no problem.
    Cockpit on LCD screens or nav screens with the matte finish are no problem.
    Not sure about Blitz in a foam cannon. I believe Phil might have the answer to this one.
  20. mobilejay
    mobilejay Birth of a Detailer
    I have used CP on headliners. Not to clean spots, but just dirty headliners. I saw some marks on mine and cleaned them up with CP and noticed how dirty my headliner was so I cleaned the rest of it. A few spritz on an MF and just wipe the headliner and it cleans it very well.
