Acids, pH and Alkalinity
Discussion in 'Car Detailing Product Discussion' started by togwt, Feb 17, 2009.
  1. togwt
    Recommended Products
    In the interest of full disclosure, I am in no way affiliated with, employed by, have any vested interest, or in any way receive compensation from the sale or distribution of the product lines reviewed or the company that manufactures or markets it.
    Results Obtained
    These articles are not intended to warrant or guarantee any results with any of the products mentioned. No endorsement of companies or their products mentioned is intended, nor is criticism implied of similar companies or their products not mentioned. The author does not provide, nor guarantee and is not responsible or liable for any third-party products or services. Brand, product and company names used throughout these articles are trademarks of their respective companies and are used for product identification purposes only.
    Proper Technique
    Skill Level / Experience
    Liability
    Product Quality and Technique
    Proceed with this in mind; the products you use constitute a very small factor in the equation. Methodology and technique constitute 95%; the reasoning behind the choice of quality products is to eliminate any limiting factors, thus enabling you to place emphasis on technique used. There is no `one correct way' to apply a product; the way detailing products are customized are what each individual finds give them their desired results
    Acids
    Acid is highly corrosive; the skull and crossbones warning on an acid label is there for a reason; acids will etch or erode anything in its path, they are also very effective in dissolving metals and etching glass. Acid will keep reacting with any surface it’s applied to if it isn't neutralized by an alkaline product. Its pH decreases when the solution is diluted with water (H20) (this results in an acid becoming more reactive (stronger) whereas the effect of water on an alkaline is to make it become weaker or changes when there are other substances that are dissolved in the solution.
    1.Hydrochloric Acid (HCI): or Muriatic Acid, its historical but still occasionally used name, this is a highly corrosive acid (pH of -1) and is often used to clean calcium carbonate build up from the inside of kettles or from around water faucets and from shower heads;
    2.Sulphuric Acid (H2 SO4): this is a common acid in both the laboratory and industry. It is both highly corrosive and economical to manufacture, which makes it the reagent of choice for many applications;
    3.Phosphoric Acid (H3PO4): this acid is used to remove rust and rust stains from metal tools and from car bodies undergoing repairs;
    4.Nitric Acid (HNO): this is another common laboratory acid used as a reagent in many chemical tests and experiments due to the fact that almost all of its products (salts) are soluble in water;
    5.Hydrofluoric Acid (HF): This acid is extremely corrosive and has the unique property of being able to etch (eat away) glass. Consequently it is used in industry to write signs on glass windows in stores and office buildings or on glass products.
    Strong acids include the heavier hydrophilic acids: Hydrochloric Acid (HCl), Hydrobromic Acid (HBr), and Hydroiodic Acid (HI). However, Hydrofluoric Acid (HF) is relatively weak.
    Acids are acids by virtue of the presence of an excess of hydrogen ions in the solution, Their salts are created when the positive hydrogen ions are replaced with positive metal ions, for example when Hydrochloric Acid (HCL) reacts with Sodium (Na) to produce NaCl with the release of H2 gas.
    Before using any chemicals or solvents, carefully read all of the cautions and medical information on the products container and / or MSDS. There is a very fine line between effective cleaning and dangerous to use products; always follow all of the manufacturer’s recommendations. Ensure that you wear eye protection and acid-proof gloves; this is mandatory. No matter how safe an acidic product is advertised, never run the risk of it splashing in your eye or it permeating your skin.
    Use a product that has a low acid concentration level, 10%, or less, with as high a pH level (> 2.0) as you can find (i.e. Sulphuric, Phosphoric and Nitric acid) this constitute a less aggressive product. A strong base (alkali) is just as corrosive as a strong reactive (acid)
    What is pH and what does it mean?
    Simply put the potential of hydrogen (pH) scale is a set of numbers between 0 and 14 where 0 is the most acidic and 14 is the most alkaline (caustic) with 7 in the middle, being neutral. Conceptually, since most people in our industry are interested in the acid side of the system, the smaller the number, and the more acidic the system.
    Unfortunately the scale is logarithmic, for every integer that the scale decreases the material is 10 times more acidic. Those of us in earthquake country know all too well the consequences of a change of from 6 to 7 on the logarithmic, Richter scale. The difference in the pH scale is just as dramatic and therefore just as misleading.
    A substance that is neither acidic nor basic is neutral; pure water has a neutral pH of 7.0 Each whole pH value below 7 is ten times more acidic than the next higher value. For example, a pH of 4 is ten times more acidic than a pH of 5 and 100 times (10 times 10) more acidic than a pH of 6. The same holds true for pH values above 7, each of which is ten times more alkaline than the next lower whole value. For example, a pH of 10 is ten times more alkaline than a pH of 9
    Representative pH values
    Substance pH
    Hydrochloric acid,
    −1.0
    Lead-acid battery
    0.5
    Gastric acid
    1.5 – 2.0
    Lemon juice
    2.4
    Cola
    2.5
    Vinegar
    2.9
    Orange or apple juice
    3.5
    Tomato Juice
    4.0
    Beer
    4.5
    Acid Rain
    <5.0
    Coffee
    5.0
    Tea or healthy skin
    5.0
    Urine
    6.0
    Milk
    6.5
    Pure Water
    7.0
    Healthy human saliva
    6.5 – 7.4
    Blood
    7.34 – 7.45
    Seawater
    7.7 – 8.3
    Hand soap
    9.0 – 10.0
    Household ammonia
    11.5
    Bleach
    12.5
    Household lye
    13.5
    A few examples of maximum acid strength might be helpful:
    Acid rain has a pH of 3.5-4.0.
    Bird excrement contain highly acidic concentrates of uric acid (pH 3.0-4.5)
    Sea water has pH of 7.75 to 8.25 Tap water has a pH of between 5.5 and 6.5
    Organic acids Citric acid, found in lemons, grapefruit has a pH of 2.0 Oxalic acid, found in spinach has a pH of 1.8
    Vinegar has a pH of 2.5
    ‘Weak’ mineral acids Hydrofluoric acid has a pH of 3.14 Phosphoric acid has pH of 2.2
    ‘Strong’ mineral acids Hydrochloric acid, aka Muriatic acid has a pH of -1.0 Sulphuric acid, battery acid, has a pH of 0
    A couple of things to note from this list are;
    a) How very strong ‘strong acids’ are
    b) How relatively weak yet dangerous Hydrofluoric acid (HL) is
    c) And how small and misleading the difference is between organic acids and weak mineral acids.
    As an example, hydrofluoric acid (HF), one of the most highly regulated, most dangerous acids and the only acid that will dissolve glass is a weak acid. d) pH decreases when the solution is diluted ( this results in an acid becoming more reactive (stronger) were as H20 effect on an alkaline is to make it become weaker or changes when there are other substances that are dissolved in the solution. e) An acids reaction with water- the hydration reaction of sulphuric acid is highly exothermic. If water is added to concentrate sulphuric acid, it can boil and spit dangerously. One should always add the acid to the water rather than the water to the acid.
    Just to complicate things a bit more, mixing some strong mineral acids together with other relatively weak acids can create a solution of "super acid". This can result in acid strengths of up to 12 times higher than either acid by itself and are not measured accurately by the normal pH scale. In theory, this is the result obtained by adding HF to other mineral acids in wheel cleaners.
    Or mixing several weak acids together can have a synergistic effect where together these acids do more than just strong solutions of each one separately.
    In practical applications, a formulator can get identical pH values by using various quantities of different acids. For example very small amounts of very strong acids or larger amounts of weaker acids can result in the same pH. The addition of a molecule of water to a chemical compound, without forming any other products is known as hydration (i.e. dilution causes the pH to decrease)
    But since pH is not a very good indicator of the strength of the acid in every system, this approach won't always produce the desired results. Each acid has properties that make it most useful for certain jobs. For example Citric acid is quite good at picking up Calcium ions in solution so acts as a good water softener where the same pH of a Sulphuric acid solution would be worthless for that application.
    My point here is that, it is not possible to judge how well a product will do the job it is designed for just by measuring the pH and stronger is not always better. So, acid strength is always relative to the system you’re measuring and what materials are in danger of being dissolved or attacked by the acid pH is a measure of the relative strength of an acid but the key word is relative. (See also Alkalinity, Potential of Hydrogen – pH)
    Information resource
    1.Widipedia - Hydrofluoric acid - Wikipedia, the free encyclopedia
    2.Index to Hyper Physics- pH as a Measure of Acid and Base Properties
    3.Material Data Sheet - MSDS -HYDROCHLORIC ACID, 33 - 40%
    4.Conceptual Physical Science - Hewitt, Paul, Suchocki, J. and Hewitt, L. Addison-Wesley, 1999
    5.Structural Inorganic Chemistry, A. F. Wells1984.
    6.Automotive Detailing Inside & Out; a Knowledge Base for the Perfectionist"– by Jon Miller
    © TOGWT ™ Ltd Copyright 2002-2008, all rights reserved
    Detailing Articles
    All original material is copyright, unless otherwise state (1) it may be copied and distributed for non-commercial purposes only provided that you retain all copyright and other proprietary notices contained in the original material, (2) the information is copied in full with no changes unless prior written agreement is obtained from TOGWT, and a reference to © TOGWT ™ is included, any unauthorized use of these materials may violate copyrights and/or trademarks
  2. blas
    blas Birth of a Detailer
    nice info
  3. Nica
    I got a question regarding the Red version of P21S. What is it's it's PH level? I mean I know the green version is safe but the red version is it as safe as the green.
    Reason I ask is because it's a 100% stronger then the green version but I don't know it's PH level? Any one know it's PH level? I'll take a stab at google as well.
    I'm just amazed at the difference between, it's incredible how strong the red version is.
  4. togwt
    Nica- The only information I have is that its pH balanced (but it has a bloody awful smell) albeit that it will clean 99.9% of dirt you get on a wheel surface
  5. Nica
    Oh it most definitely has an awful smell, but the way it pulls the grime of the rims is mind shocking. I don't use it often as I only have a limited amount for the time being but every time I use it I'm shocked at the huge difference between the green version and the red version and I can't help but wonder if the red version is just as safe as the green version. Good to know that it is a PH balance product though, I'll do a bit of digging as well and see what I find.
    Thank you for the feed back though :peace:
  6. supercharged
    Sounds like even Megs Wheel Brightener is safer then coke. I told ya all - dirnk Pepsi! Coke tastes like medication.:gross:
  7. hockeyplaya13
    hockeyplaya13 Any Rag Vehicle Washer
    I found the GWK for P21s Power Gel. I'm in the process of translating it from Slovenian. I mean I've translated it, but it lost all formatting so I'm trying to copy the formatting of the original document as best as possible to keep it readable. Will upload when I've finished it (hopefully tomorrow).
  8. hockeyplaya13
