35th Anniversary Camaro SS by TSC17!
Discussion in 'Show and Shine' started by TSC17, May 25, 2009.
  1. TSC17
    TSC17 Any Rag Vehicle Washer
    2002 35th Anniversary Camaro SS Limited Edition
    To commemorate the Camaro and the end of its production, Chevrolet developed the Limited Edition 35th Anniversary Camaro SS for 2002. Just 3000 units were scheduled for production in the U.S., and 152 for Canada. The LS1 V-8 powerplant produced a conservatively rated 325hp and 350 lb-ft of torque.
    The owner of this car contacted me last fall, and we were just now able to get this car in to be worked on. It only has 2600 miles on the clock, but 7 years of time on the finish. Overall it was very clean with a high gloss, but even as a garage queen it had plenty of deeper scratches from less than perfect washing and drying techniques. After I was done with the car I spent a bit of time with the owner teaching her how to properly care for it so she can keep it looking nice.
    For those who normally read my posts, you know that I have a tendency for being long-winded with an overload of photos. For this one however, I am going to try my best to keep it brief!
    First up was the obligatory foam gun wash with Chemical Guys Citrus Wash & Gloss at paint prep ratio (2oz/gal) to remove the obvious layers of wax.
    After washing I brought the car back in the garage for claying. I used Chemical Guys mild clay with Dodo Juice Born Slippy clay lube. I was amazed at how clean the surface was, and had difficulty finding anything to remove. Then I proceeded to do an alcohol wipedown to make sure I had an absolute clean surface to polish.
    Unfortunately Chevrolet decided to apply vinyl graphics on this car, so it required a tremendous amount of tape to protect all of the edges.
    Out in the sun, you can get an idea of the condition of the paint:
    Under the halogens, the deeper scratches show up even better:
    The hood had the deepest and most severe defects, so it required a little more muscle to correct. For this area I used Super Intensive Polish with a Micro Surface Tuff Buff black wool pad. It took a couple of passes, and left some holograms. I was able to clean it up with 106FF and a white pad, and then finished it off with PO85RD and a red pad. The amazing part of the hood and the trunk lid was that they were almost completely free of orange peel. You could tell that they had been sanded and polished smooth, but not the sides of the car. The owner said that there had been no body work done on this car, so I have to assume this was done by the factory.
    For the rest of the car, I used SIP and an orange pad, and then went directly to PO85RD and a red pad to amp up the gloss quite a bit. I did a test with 106FF/white afterwards, and found there was no discernable difference in the finish by going directly to the finer combination, so I chose the PO85RD because I find it easier to work with than 106FF.
    Here’s part of the trunk lid before and after SIP/orange. You can tell that some of the RIDS are pretty deep:
    After just SIP/orange and before final polishing:
    I didn’t spend a lot of time on the “during” photos, so now I’m going to go straight into the after shots.
    I performed IPA wipedowns after each polishing stage to ensure I was getting proper correction. Once I was done, I sealed it with Optimum Poli-seal. Although carnauba paste wax looks tremendous on red, I chose to go with Optimum Spray Wax because all of the intricate vinyl decals. Removing paste wax from all of those edges can be quite time consuming, and I didn’t have that kind of time on this particular job.
    When all was said and done, I was able to get about 95% of the defects removed. There were some between the vinyl graphics that could only be made “better”, but the finish overall had a new depth and gloss to it that it hadn’t seen in quite a while. The owner said that it looked better than when it was originally delivered off of the truck 7 years ago.
    By this time the sun was deep in the sky and I was fighting the clouds as well, so I couldn’t get the best sun shots. I think you can tell though that the finish was pretty clean.
    Here you can get an idea of just how smooth the finish was on the hood. Notice how clean the reflection is of the T-5 fluorescent light fixture.
    Got gloss?
    For an aging body style, this is still a very good looking car!
    This doesn’t show much, but I liked the photo…
    The tail lights got polished up as well.
    I like how Chevy designed the front end of this car, which is easy to tell because I took a lot of photos of it.
    Use your imagination, and the front end has a bit of an anime look about it.
    Between the contours of the spoiler and the graphics, this area was pretty challenging to work on.
    If you look closely at the edge of the badge, you’re seeing adhesive and not polish residue. Also look at how much orange peel there is on the sides in comparison to the hood shots that I previously pointed out.
    As always, thanks for taking the time to review my work.
    Total time = 9 hours.
  2. 02CAMSS
    02CAMSS Jedi Nuba
    Love that car!! Great Job!!
  3. supercharged
    Came out awesome!!! I gotta admit I like red color!!!
  4. Nica
    Vehicle looks great, well done :thumb:
    As for lengthy write ups, I personally enjoy reading and seeing lengthy write ups, in my opinion it gives the reader (me) the sense of being there wile you detailed the vehicle. So in my opinion the more the better :cheerl: The only draw back is that it takes a bit of time and effort to do such write ups.
  5. SSTG
    SSTG DB Forum Supporter
    Hehe wonder why.
    Beautiful car, and one heck of a job you did there.:thumb:
  6. P1et
    Excellent work as usual. Red is one rewarding color!
  7. mrgolfrider
    I miss the crazy write-ups from you Todd!! Lets not make it a standard for this short and sweet one. Did I miss something in your lack of information, or was there really nothing done to the interior?
    Amazing results as usual!!
  8. TSC17
    Thanks everybody!
    Yes, the extensive write ups can take a tremendous amount of time to do right. I've been doing so many of them lately that I just wanted to back off a little this week because next week I have a car coming that everybody is going to be interested in...so I'll save photo and info overload until then!
    I hope the weather cooperates because this next car will provide some great eye candy if the sun is out.
    Oh, and yes this was an exterior only job on the Camaro.
  9. Denzil
    Looks really good there Todd! I do like the looks of this Camaro but I think I'll like the newer ones even more.
  10. Reflect
    That looks awesome man. I used to be in love with the f-bodies.
  11. agpatel
    Looks great, I loved the 35th Anniver when it came out. Now if I could get my red car to look the same I would be happy...
  12. J BELL
    J BELL Nuba Guru
    Awesome job on a beautiful car
  13. MrPolished&Waxed
    great work. 9 hrs is pretty good. Did you do the interior at all? I would love to come work with you sometime.
  14. detaildoc
    detaildoc Guest
    Awesome job!
  15. Buddy
    Nice detail...It looks great...That was a good idea about backing off on the write. It was still very enjoyable...:thumb:
  16. kei169
    kei169 Wax on..Wax off
    nice job!!! Very nice Final pics.....The shine and gloss is insane!
  17. michakaveli
    Thanks for posting, nice job!
  18. DLR Detailing
    DLR Detailing Jedi Nuba
    Very - very nice! :mounty: Enjoyed the write up as well. :applause2: I'm with Nica, the more the better on pics and details of the job. Thanks for taking the time to share your work.
  19. Hostage1978
    Hostage1978 Guest
    I hate these cars and you made me like them!
    Excellent work, I enjoy reading your write-ups... please keep them coming
  20. corrswitch
    corrswitch Jedi Nuba
    Wow, it looks great. Not sure how to describe the front. As you said, it looks anime. So let's say I'm speechless :)
