Today after cleaning my wife's cars wheels with our trusty Sonax wheel cleaner we decided to do a comparison between the Sonax and our past favourite wheel cleaner, Meg's Hot Rims. Right side wheel to be cleaned with Sonax Left side wheel to be cleaned with Megs Sonax wheel cleaner applied and left to work for a few mins Rinsing. After. Megs hot rims applied and left to work. Rinsing. After. And to compare one last time... Sonax top, megs bottom. As you can see the Sonax did a far better job of removing the brake dust than the Meg's did. Again no brushes were used, this was simply a test to see which product applied and rinsed with a pressure washer would lift the most dirt. Also worth noting is the etching the Meg's left on the exposed metal of the brake disks, the Sonax left no such marks as it is a ph neutral product :woot: When used with brushes the Sonax is still by far superior to the Meg's and effortlessly lifts the brake dust with minimal scrubbing and working :woo:
Wow...wonder why they don't sell Sonax over here... pH neutral ey, sounds like a really good product!
Quick update for those who were unsure about the content's, ph, ect........ I obtained the MSDS for the wheel cleaner and it states the tested ph as 7-7.5. As you can see from the table below, a ph of 7-7.5 means it is in between fresh water (7) and salt water (8) and roughly the same as blood. The MSDS is available from here Hope that helps :mounty:
Wow how did I miss this review, very nice comparison. I can't say I've used any of these products but a well done review and not to mention very informative :thumb: Thank you for taking the time to share with us eace:
Thanks Nica, trying to contribute where I can. Learn so much cool stuff on here, it's nice to be able to give something back for a change ;-)
Ah yes, I understand where your coming from but that's what this forum is all about, learn and share..we all know a little bit and we all contribute and the more we share well the more we all lear :thumb: every little bit helps eace:
