Deep Wheel Cleaning and Coating
Discussion in 'Show and Shine' started by HUMP DIESEL, Sep 14, 2015.
  1. HUMP DIESEL
    HUMP DIESEL New Member
    These wheels were part of a full correction and coating on a 2009 Lexus RX350. I wanted to focus on the wheel cleaning, because I actually think this is an overlooked service that consumers should have performed at least once a year.
    As you will see in the pictures, this was a wheels off detail. This is the first main point of the detail. I feel that pulling the wheels off and deep cleaning them is a great way to keep them looking new for years.
    Products used:
    Sonax Full Effect wheel cleaner
    Various brushes
    Stoner Tarminator
    P21S Total Auto Wash
    Coating: Modesta BC-06 spray application using and airbrush.
    As you can see, first we must put the vehicle on jack stands or use a dedicated lift to get the wheels off.
    This image has been resized. Click this bar to view the full image. The original image is sized %1%2.
    Wheels set at the back of the shop. I did not want to get any cleaner on the vehicle, because at this time the paint correction and coating application had been performed.
    One thing of note is that I keep these wheels cleaned on a regular basis. I use the SpeedMaster brush always to clean the barrels, but as you will see, deep cleaning is still needed.
    Sonax Full Effect starting to work
    Looks like I cut an artery!
    I actually agitated the wheel cleaner at this point to help with the decon.
    Rinsed and tar removed. The textured areas still hold some deep embedded contamination.
    Take the time to polish the exterior of the wheels at this time
    Deep clean the tires as well
    At this point the tires are cleaned and un-dressed.
    Great time to clean the inner wheel wells that you never see.
    Cleaned and dressed
    Final pic on the vehicle after coating
    Now these wheels will stay cleaner longer and when they are cleaned,it will be much faster.
    Enjoy,
    HUMP
    Activa 2 likes this.
  2. detailersdomain
    nice work thanks for sharing.
    HUMP DIESEL likes this.
  3. drbll
    drbll New Member
    Looks great! What did you use to dress the wheel wells?
  4. mShu7
    mShu7 Birth of a Detailer
    Wow, those look incredible!
