Gyeon Quartz: Q2 Trim review
Discussion in 'Car Detailing Product Discussion' started by GlossAngeles, Oct 30, 2014.
  1. GlossAngeles
    GlossAngeles New Member
    Gyeon Q2 Trim is a quartz based plastic and trim coating.
    Price: $39.95
    Price per oz: $39.56
    Consumption Rate: 30ml will do 5-10 cars
    Price per Vehicle: $7.99-$3.99
    Ease of Application
    On plastic trim: Extremely easy, simply put a few drops on your suede applicator and wipe onto the surface. Wiping off is normally not necessary.
    On headlights/tail lights: Same as on trim, but it is necessary to wipe off the excess.
    On rubber trim: This is a bit more difficult. The rubber is much more porous and thus will begin to absorb the product at different rates and become splotchy. A second application is often needed to smooth the finish out.
    Level of Shine
    No shine added at all. Plastics and rubber become darker and have a much richer look without adding gloss.
    Protection
    Stated to last over 9 months and to be unaffected by anything from 9-11 on the pH scale. These claims are definitely true. We applied Gyeon Trim to a test spot and attempted to remove it with ammonia, isopropyl alcohol and vinegar, all to no avail. The beading and hydrophobic properties are absolutely amazing. It has the same hydrophobic effect as paint coatings, but on trim pieces. However, the best attribute of this product is the UV protection for over 9 months. Here in California we have very severe sun that damages headlights and trim pieces extremely quickly. The UV protection and oxidation resistance this product has makes it a MUST for people in climates with severe sun. It will protect your trim from oxidizing and becoming grey, and your headlights from becoming yellow and hazy.
    Pros
    Extreme [SIZE=15.5555562973022px]protection[/SIZE]
    Long lasting
    Great finish
    Cons
    A bit tricky on rubber due to the porous nature, which will differ from vehicle to vehicle, so often times a second application will be needed in these sections.
    Conclusion
    Gyeon Trim is an amazing product and an absolute MUST for people in climate with severe sun. It offers amazing protection, even in severe conditions, and lasts a very long time. The price point is unbelievably low for what you are getting. If you don’t want to worry about trim, plastics or headlights oxidizing and fading, Gyeon Trim is a great option for you.
    Similar Products
    Cquartz Dlux
    Gtechniq C4
    22ple VR1
    Optimum Opti-Lens
    rwisejr likes this.
  2. JordanL
    JordanL Virgin Detailer
    I'm loving these reviews! Great work!
  3. rwisejr
    rwisejr DB Forum Supporter
    looks interesting
  4. Jeepbroner
    Jeepbroner New Member
    New to the forum, I'm learning so much. Thank you!
