Hello I have Cquartz applied to my car. I am trying to find some products that I can carry with me (in the trunk) to remove bugs/ etc in long drive. Is there any product that does not degrade the Cquartz? Thank you!
Try a diluted APC. But if the bugs are relativity fresh then use some Ultima Waterless Wash to remove them. It won't degrade the coating and leaves the surface protected with polycharger and super slick.
I would agree an apc should do the trick or a bug and tar remover, I have had great success with it on Opti Coat but have not tried it with Cquartz.
Thanks for the reply. If you don't mind, would you tell me what APC is? is this All Purpose Cleaner..? if so which brand do you recommend? Thank you!
1z anti insekt, very effective just make sure you have a good quality microfiber cloth. All I use for bugs, helps keeping hydrophobic properties of the coating over apc. http://www.detailersdomain.com/1Z-einszett-Anti-Insekt-Bug-Tar-Remover_p_107.html&cd=1&ved=0CB4QFjAA&usg=AFQjCNEUEkQ063Bhc43yOR2C6GOUm9Vjow
Same here. Did you research anything in that product line? I think the Car Pro Reset shampoo might be of interest to you. Good Luck!
