Brown stuff on tires?
Discussion in 'Detailers Domain' started by awdpwns, Jun 24, 2012.
  1. awdpwns
    awdpwns Virgin Detailer
    Hey guys since i picked up my new audi s4 its had brown tires. The cars tires were covered in mud when i was looking at it. The mud must have sat on them for a month or 2. I told them not to pdi it. The following morning i washed off the dirt but there was still a brown layer left on the tire sidewall. Does anyone know what this is or how to get it off? Ill post pics later tonight. Thanks
  2. chemgys99
    chemgys99 DB Forum Supporter
    Spray Cg grime reaper 4-1 or Meg's super degreaser 4-1. Let it sit for couple minutes(out of sun). Respray and scrub with a brush. Rinse and dry down. Also te brown could of been from a shity tire dressing.
  3. DirtyWeRX
    DirtyWeRX DB Forum Supporter
    If its not entirely mud, then it's brake dust. I work in a tire shop and see it all the time. Spray some APC and scrub it down really well. Yu may have to do it a couple times but should clean up
  4. detailersdomain
    got any pictures?
  5. obsidian LGT
    obsidian LGT Birth of a Detailer
    That definitely sounds more like brake dust. German cars are horrible for it! Previous is correct, APC should take care of it. If not, griots garage makes rubber prep that works quite well.
  6. Frankastic
    Stoner's Tarminator = your friend :) just a light spray on a towel and wipe
  7. M3ride.
    M3ride. Wax on..Wax off
    +1 on the Griot's Rubber Prep that stuff works very well. But like others have mentioned, use a good APC and scrub, scrub, scrub.
  8. vtec92civic
    vtec92civic Nuba Guru
    post up some good photo's so we can all have a look at exactly what you're working with.
  9. sikedsyko
    sikedsyko DB Forum Supporter
    I'd try Mother's wheel and tire cleaner on it, or any tire cleaner that foams up. Spray on, scrub it in, rinse, repeat.
  10. Darkstar752
    Darkstar752 Horizon Detailing
    +1 :)
  11. detailersdomain
  12. togwt
    If this brown discolouration is only on the tyres not the wheel surfaces it could be the tyres in-built protection (Antiozonant)
  13. awdpwns
    Sorry this is the only pic i could snap of the tire before it started downpouring again. But yea 2 days ago i tried some WD40 with a paper towel and it got a noticeable amount of it off but some of its still there..
  14. detailersdomain
    stoner's tarminator should clean that up nicely.
  15. awdpwns
    Alright ill order some tonight. Thanks!
  16. blackTL
    blackTL Any Rag Vehicle Washer
    Haven't tried tarminator, but I had the same problem and Meg's apc 4:1 helped clean it up.
  17. supercharged
    Autoglym CWC will take care of it...
  18. togwt
    The key to tyre dressing durability is deep cleaning the tyre, spray or apply your cleaner allow to soak in for a minute or two and then scrub with a fairly stiff tyre brush, once clean you should be able to take an old white dry terry towel and rub the tyre surface, it should be almost pristine (if not repeat). Tyre cleaner needs to be strong enough to tackle a heavy build-up of tyre dressings, silicone and road grime, but not damage wheel coatings.
    A quality citrus-based cleaner
    (P21S® Total Auto Wash) should clean the tyres down to the original rubber surface, this is especially important when you apply a new dressing, as dressings won't adhere to, or create the right shine on dirty rubber or silicone residue. This tyre cleaner is a strong concentrate; spray-and-rinse, without scrubbing, if you are starting on an old, neglected surface, use a fairly stiff tyre brush for the first application and a spray & rinse at least 3-4 times a year
    Alternative products – Optimum™ Polymer Technologies - Power Clean (diluted 3:1: to 5:1)
    Griot’s Rubber Cleaner and Griot’s Rubber Prep - two excellent products for cleaning rubber; Rubber Cleaner is for regular cleanings; like a car wash for your tires. Then, for more serious cleaning, there’s Rubber Prep, is an intense cleaner for heavily soiled rubber tires, trim, mouldings, seals, and hoses. This gel rubber cleaner removes old dressings and road grime to prepare the surface for a coat of rubber dressing by getting down to the bare rubber
  19. Meticulous-Detail
    Meticulous-Detail DB Forum Supporter
    Just picked up Megs New Foaming All Wheel and Tire Cleaner and this stuff is awesome on both the wheels and tires. Foams up nice and doesn't run. The tires comes so clean you don't even need to dress them. I just cut out APC for tires on my details with this stuff.
    All of the above suggestions will work great too!
  20. Earlyworm
    Earlyworm Any Rag Vehicle Washer
    Amazing Roll Off works for me. Agitation not needed.
