Subject: 2000 Honda Civic Requirements - Remove heavy swirls and scratches, and protect with Opti Coat Exterior - Wheels were prepped with Sonax Wheel Cleaner and cleaned up with various brushes - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down - Wheel wells were cleaned up - Washed with 1Z einszett W99 - Aquartz Iron Cut - Wash down and rinsed - Door jambs were cleaned up - Nano Scrub AutoScrub - Dried - Tires dressed - Masking - Paint Measurement - Wetsanding - Meg's M105 with Surbuf Pad - Griots Orbital - Meg's D300 with Microfiber DA Cut Pad - Griots Orbital - Menzerna SF4000 with Uber Green Pad - Griots Orbital - Opti Coat - Inspection with Fenix, 3m Sun Gun, Infratech, and natural sunlight - Wheel wells were cleaned and dressed - Rubber and Plastics Treated - Exterior windows and mirrors cleaned and sealed - Exhaust tips cleaned - Windows were autoscrubed, cleaned, and sealed Products used Links to products used - 1Z einszett W99 Aquartz Iron Cut Sonax Full Effect Wheel Cleaner NanoSkin AutoScrub System Meg's M105 Meg's D300 Microfiber Correction System Menzerna SF4000 Opti Coat Adam's Super VRT Optimum Metal Polish Tools used Uber Wool Wash Mitt Uber No Name MF Towels Griot's 6 inch Random Orbital Polisher Uber Buffing Pads Defelsko Paint Meter Fenix TK35 Brinkmann Kranzle Pressure Washer Cam Spray Foam Canon 2 Grit Guard Buckets with Caddies Uber Firehose Nozzle Metro Air Force Blaster Before Prep - Wash, Wheels, Tires, NanoSkin Headlight restoration Before shots of the lights. Various stages of wet sanding required to clean up the headlights Compound and Polish After shots of the headlights - Opti Coat installed D300 with Griots 50/50 shots of correction Before trim After After shots
Freaking awesome results! From your experience does the 1Z Deep Plastic Cleaner remove the "scuff" marking looking stains on hard plastic? And was that the SVRT you used on the trim?
wow!! from prius to this?! haha nothing but sickness here. BTW your shinex came with 5/8 thread? I see that you're using my favorite 3 in backing plate hehe
thanks guys yup we don't just do exotics and super cars here , our Festool is a US model so yup it works with all the us spec backing plate.
You straight up hammered away on a hammered car! : applause: What were the ptg readings? If you remember...
Very nice work but mildly puzzling, I'm surprised that an owner would spring for that level of correction on a non-Si 2000 Civic. I'm a Honda fan (with the qualifier that Honda/Acura seem to have lost direction to a degree in the last decade or so) and I agree that it is nice to see something other than Audis, Bimmers, etc. but it still seems a little discordant. An '89 CRX Si, a 2002 S2000 or even a '97 Accord wagon would have been less surprising.
sure I was surprised as well. customer is in grad school and wanted to keep this car for a long time. so he wanted the best for it.
