Hi There A white pearl GT-R R35 with 15000 kms for a Estado de Concurso , covered in swirls , rids and holograms. Came after a jet wash but it´s hard to kept the bugs away from the Godzilla A lot of heat from that exaust pipes and no ordinary wash can´t remove that coal away . Very impressive the lack of care from tire shops around here... Time for washing and claying Metalic parts dissolving Some hours later the car is washed and prepped for paint correction Taking some notes of the clear we found that the R35 had some clear coat removed. Starting from the bonnet Grills removed An before and after with sun gun Roof Areas near the roof right fender 5050 Front bumper Doors Rear sideways During some PDR Nissan symbol removed for a clean rear Wing Trunk a deeper scratched removed Lights someone waiting for his turn :roll: a small test spot bumper. sideways lower trim Interiores headlights Some days later the car looked whiter by far but a lot of work waiting. Motor 5050 Ready to assemble Detailed grill Motor ready The day of rimms , wheel arches and exausts Washed and full of marks by someone sufering from parkinson with a screwdriver to remove glue from the weights... After Obrigado aos técnicos por deixarem salpicar óleo de travões sobre as maxilas... 5050 Starting the interior 5050 of the leather and the interior needed a good TLC Removed all the interior parts of the trunks and detailed them as soon they were assembled. Finished interior After 9 crazy days and a lot of work , it´s SHOWTIME A money shot Sun gun Outside it shines a lot THE END Regards Rui
Great Job!! Thanks for sharing. Ton of work there. I have yet to get a GTR with high paint readings,strange. I did a new car prep 2010. The highest reading I got was 108 on the roof the rest were scattered all over the place. Great work again. Darren
This correction is "Winning"...... tightness in Portugal, and your wife helps you Rui.........unless in the one pic you are letting your nails get a little long.
