Uber pads
Discussion in 'Car Detailing Product Discussion' started by emm11, Apr 28, 2011.
  1. emm11
    emm11 Virgin Detailer
    How do uber pads compare to Lake country pads? I wanted to try them out and was wondering how they compare? I like how LC has a couple of different wax pads. So I can use different color for different waxes. Is the black uber pad the only wax pad? Or can I use the blue uber for wax also?
    Thanks
    Ed
  2. Rcrew
    Rcrew Wax on..Wax off
    I switched to using ubers a few years ago from LC and they perform great. I still use a LC wool mainly because uber doesn't have a wool offering.
    To be fair, I wouldn't say they perform vastly better/worse than LC (although I just got some hydrotechs to try out, so we will see if the hype is true).
    The black uber is the only 'wax' pad, the blue is a finishing pad with a super mild amount of cut.
  3. detailersdomain
    you can use black or blue for wax but black is softer.
  4. emm11
    Which pad would you use with an AIO?
  5. emm11
    Hey Phil,
    Do you use the blue with liquid waxes/sealants? Black with paste?
  6. detailersdomain
    nope I use liquids with black and with paste I do it by hand.
    you can use either for an AIO
  7. emm11
    Thank you
  8. dave_zok
    dave_zok DB Forum Supporter
    If you get some Uber pads you won't go back to LCC. I think the uber pads are much softer and becuase i find them easier to clean my have lasted longer.
  9. Misha
    Misha Nuba Guru
    i used both. i like both of them but for 4" id have to say i like uber better
  10. P1et
    The Uber pads are excellent. I have them all, the only one I don't like is the orange one. It's just too stiff. But the green one is just about the best pad there is. Very versatile.
  11. Wheelz25
    Wheelz25 Jedi Nuba
    Same here, the orange one is the only one that I hesitate to use. Green pad is awesome, moves so smooth and just really easy to maneuver. And I do use both black or blue for liquid waxes. haven't had any issues. I don't think the difference between the two will cause any harm when using waxes.
