Instrument Cluster Scratches
Discussion in 'Interior Car Care' started by BoostedMk6, Apr 15, 2011.
  1. BoostedMk6
    BoostedMk6 Jedi Nuba
    One of my regular customers brought me his 2008 GTI and asked if I could remove some fine scratches in the plastic instrument cluster along with the normal detail. I have never done this before, so does anyone have a method that works? The scratches are very fine.
    I do have Megs Plast-x and Menzerna polishes.
  2. Kaban
    Kaban Welcome to Detailing
    I wanna know too.... My dad's van has a ton of scratches on the instrument cluster and it takes away from an otherwise clean interior.
    I saw this video a few weeks ago and it's definitely applicable to your question.... Watch how this guy gets the job done. But this method would be tough to use in some situations where there is little room for a buffer:
    YouTube - Innovative Detailing presents "TODS" The Other Detailer's Scratches
  3. Polygon
    Polygon Virgin Detailer
    I honestly wonder how well some of these head light lens polishing kits might work for this? I have new plastic to go over the cluster in one of my cars. I might just have to test is out.
  4. Kaban
    Like PlastX? Hm.... good question. I got a bottle I might try that and see what kind of results I get.
  5. irontree
    irontree Two Bucket System Washer
  6. kyoshiro
    kyoshiro DB Forum Supporter
    do remember that some dashes have a matte coating ontop so watch out when you're polishing.
    you may end up having a shinier dash than you want =p
  7. Frankastic
    I think you will have to remove cluster from the dash to do so....good luck!
  8. Legacy99
    Legacy99 Wax on..Wax off
    Isn't this thread about plastic lens?
  9. GDAL
    GDAL Super Moderator
    Plast-X works great. You need to use a terry towel (more bite) for the initial buffing. You should do the final buffing with a yellow applicator. Patience is key. It takes a few buffings before you start seeing any improvements.
    I removed scratches from the shifter and cluster my 06 highlander when I first bought it.
  10. imaj
    imaj Any Rag Vehicle Washer
    THis begs the question...How does one clean the plastic that covers the instrument cluster? I hear that plastic is super sensitive.
  11. Kilo6_one
    Kilo6_one DB Forum Supporter
    depending on the car, you can actually snap most of the plastic lenses off the actual cluster, just be careful not to touch any of the dials.
  12. kyoshiro
    Sorry I have failed my comprehension of instrument thingy
  13. BoostedMk6
    I'm going to give PlastX and a foam applicator a shot.
  14. Chris@Optimum
    Chris@Optimum DB Certified Manufacturer
    I remove the trim to expose all the edges of the cluster lenses and just polish with Optimum Polish II and my 3" pads that fit on my drill...only takes about 5-10 minutes.
  15. StanVanDam
    StanVanDam Virgin Detailer
    Some detailers remove scratches from external plastic door pillars using Menzerna PO203S and a white pad. This may or may not work on the instrument panel plastic, and you would probably have to do it by hand.
    Zaino Z-14 Plastic Cleaner and Polish is another product you may want to examine. I haven't tried it but their other products are pretty good..
  16. Handz
    Handz Obsessive Detailer
    Soooo, Ever since I bought my car *I have had these stupid scratches on my Gauges cluster housing. IT HAS ALWAYS PISSED ME OFF!!!! I got tired of looking at these light scratches in the light So i removed the cluster to handle business.
    All Work Was done by Hand
    -3M Rubbing Compound
    -3M Plastic Cleaner'
    -3M Plastic Polish
    -CG MF Towels
    Removed the Cover Bolts....
    Exposed the Cover and cleaned all the dust off the inside.
    3 Steps to Corrected the Plastic.... All Done by Hand Using CG MF Towels
    I picked up the Chemicals from Detailing.com and wanted to go all 3M on this one.
    -3M Plastic Polish
    Looks LOT better!!!
  17. Bmer89
    Bmer89 DB Forum Supporter
    Mine are pretty bad on both my cars. Yay for buying old cars from people who could care less... Looks like that method worked pretty well for you Handz, I'm going to have to pick up some plastic cleaner and polish! Already have the rubbing compound, that stuff is amazing.
  18. Auto Concierge
    Auto Concierge DB Pro Supporter
    Another great combo is CG extreme wet glaze followed by the new Megs D301 finish polish/wax, used this combo today on plastic Porsche speedo covers and they were pretty bad...........used a 100ppi foam applicator and it took awhile but too aggressive of a applicator will re-marr the surface, just one of those tasks that requires time.
  19. kyle butler
    kyle butler Birth of a Detailer
    this is my question as well. i have some minor scratches and dont want to add any more.
  20. Chaseme
    Chaseme DB Forum Supporter
    Seeing that it's mostly dust build up use compressed air. But other than dust everything else is a different story and I can't help you out.
