Brand new 2011 Bentley Continental GTC The car is garage and weekly wash. In this case I use onr in quick detailer dilution assist by a thick microfiber towel to wipe down the paint. After quick detailer wipe I claybar the car by using an fine grade claybar and onr in quick detailer dilution. After each ½ panel I inspect the clay and mold it to a clean surface. The next step was prep for correction by tape chrome trims , rubber trims and badges. Once the car was prepared for correction I inspect the car with halogen light to get familiar with what type of defects I have to deal with . initial condition of the vehicle: Pass door Driver door: Driver door pic close up Pass door was chosen for test spot. After I try multiple pad , polish combination the winner was 1 step with mezerna SIP ( super intensive polish) on LC light green cutting pad with flex da. The correction was done in speed 6 and after that few more passes with speed 5 and light /no pressure. The test spot was wipe down with ipa ( 50/50 alchool and water) and inspected under halogen lights: Most of the correction was done with main light off and assist by halogen light. A few after pictures : Pass door: Driver door after Remember the before? A close up after correction: The wheels were clean just light dust , a microfiber towel and optimum car wax took care of that. On the tires I use meguiar`s m40 and a soft sponge to apply it. The front of the car was clear bra , after wash was protected with rejeX apply with a foam applicator pad. The whole paint was protected with 2 coats of duragloss 105 . Enjoy the after shots , thank you for made it all the way here:
it look like pigtails , each panel has 1-2 spots. on the trunk was obvious dull from unfinish surface.
nice job... FYI if you're not a Forum Supporter you are not allowed to have any pics with your business info on there.
