Gleaming Kleen - Caterham CSR
Discussion in 'Show and Shine' started by Jayplay, Oct 13, 2010.
  1. Jayplay
    Jayplay DB Pro Supporter
    Owner of this recently drove it across Europe and wanted a good clean to remove the build up of dirt and tar from the trip before putting into storage for the winter.
    A bit about the CSR 260
    The Caterham 7 CSR is the latest evolution of the Seven design. It sees the long-awaited return of Cosworth to the road car market after a ten-year absence with two bespoke, high performance engines. The new model also benefits from the introduction of a fully independent rear, and inboard F1-style, front suspension plus major aerodynamic and chassis enhancements.
    Engine: 2.3 litre Cosworth Duratec
    Max Power (bhp/rpm) 260bhp @ 7500
    Max Torque (lbs ft/rpm) 200 @ 6200
    Weight 575kg
    0-60mph 3.1 Seconds
    Power-to-weight 452bhp-per-tonne
    Top Speed 155mph
    First thing we did was wash the car then jacked the car up to remove the wheels. I cleaned the arches and suspension whilst Matt cleaned and protected the wheels.
    Arches/suspension sprayed with BH Surfex and then worked with a brush and then Tardis was used to remove the tar.
    Before
    After
    Wheels cleaned with Epsuma Revolution with tyres being cleaned with Megs Super Degreaser. Once wheels clean they were given a IPA wipedown and then Nanolex Premuim Sealant was applied. Tyres dressed with Zaino Z16
    Exhausts were polished using Brillant Metal polishes and Megs DA with the hard to reach bits done by hand
    Paint work was given a single stage machine polish to lift the paint and remove some of the swirling
    50/50
    Swissvax CF was applied/removed then 2 coats of Swissvax Best of Show was applied.
    Matt started work on the interior with leather being down with LTT products and Einzett Cockpit Premuim used on all plastics
    Exterior plastics cleaned with Swissvax Plastic Wash and all seals treated with Swissvax Seal Feed
    Engine bay was given a good clean and dressed
    Before
    After
    Few finished shots
    Thanks for looking
  2. P1et
    Very nice work on this one! These are such a bastard to clean I bet...
  3. tdekany
    tdekany Wax on..Wax off
    Fantastic finish!
    How did you clean the radiator?
  4. Wheelz25
    Wheelz25 Jedi Nuba
    nice detail! that things looks a like blast to drive
  5. supercharged
    Great job!
