leather masters
Discussion in 'Interior Car Care' started by nyrep1, Apr 19, 2010.
  1. nyrep1
    nyrep1 Obsessive Detailer
    trying to decide between leatherique and leather master...what are the essentails for the lm kit?
  2. mrgolfrider
    From what I understand it is essential to have all three parts of the kit, Strong, Vital, Protect.
  3. nyrep1
    too the folks who have both which do you like better? i have the feeling they are for different purposes and i need both but it seems like everybody has a different feeling on them and which is the right product for what situation
  4. agpatel
    agpatel OD On Detailing
    For the LM kit you would need strong cleaner, vital, and protectant. It is an amazing trio combo.
  5. mrgolfrider
    Well first off this isn't really a product you want to use all the time, its not cheap. Only really old dry cracked seats I would do the Leatherique RO and then you could follow up with LM Protect. The Leatherique is going to bring back that new supple feeling of leather that we all love. It is a time consuming process, but a little patience reaps big rewards!
  6. nyrep1
    so leatherique for bad cases (up charge of course) and what for condition or maintence
  7. Audi2.7t
    Audi2.7t Two Bucket System Washer
    The leatherique dou (Rejuvenating Oil and Prestine Clean) is meant for restoring dry, cracked seats. Although i'm sure you could use it every time you want to clean your seats, it just wouldnt make sense because they are expensive products and just arent MEANT for regular maintenance.
    For regular maintenance, I would use the LM Trio (strong or soft/vital/protect). Depending how how dirty the seats are, you can either get the strong or soft cleaner. I would go with strong, just because you can always dilute it to make it "soft."
  8. Aesop
    Aesop Jedi Nuba
    Leather Masters will handle nearly everything, in extreme cases you should look into the Gliptone leather conditioner from the UK. Its some great stuff for dry leather.
  9. GDAL
    GDAL Guest
    Is gliptone sold here in the States?
  10. Aesop
    Aesop Jedi Nuba
    It is but its really hard to locate it. There is quite an influence of it in my area yet I have never been able to find the distributor.
  11. supercharged
    you cannot go wrong with Leather Masters.
  12. bakchoi
    bakchoi Birth of a Detailer
    does it have any UV protection? I didn't find it mentioned on the site.
  13. D&D Auto Detailing
    If you dont have a vert or an older car than it doesnt really matter.
  14. froboy272
    froboy272 Obsessive Detailer
    if you ever leave windows open and the sun shines in it does
  15. 3Guy
    3Guy Virgin Detailer
    check the glipstone web site.
  16. yakky
    yakky Two Bucket System Washer
    Leather Masters is great for leather that is in ok shape. For trashed leather, Leatherique is pretty good, but I also really like Griots leather rejuvenator, though be sure to follow the directions for leaving the windows down, you think AA made a mess outgassing.... this stuff will amaze you.
  17. PDJ3.2
    PDJ3.2 Birth of a Detailer
    I have both and you really can't go wrong with whichever you choose. If I had to recommend one over the other, I would probably go with Leatherique because RO rejuvenates unlike any other leather product. Also PC is very versatile, as it is an effective cleaner with light conditioners, you can use it to do your maintenance cleanings and you can use it on vinyl and rubber too. For example, I also use it on my door seals.
