Which Pressure Washers Pack The Most Power?
Discussion in 'Car Detailing Product Discussion' started by siyamythew, Dec 15, 2009.
  1. siyamythew
    siyamythew Virgin Detailer
    Of all the pressure washing machines on the market, steam pressure washers easily rank among the most powerful. These industrial pressure washers are great for heavy duty industrial projects and have far more cleaning power than commercial pressure washers utilizing cold water or even hot water. However, to get the most out of them, it is important to understand what makes these water pressure washers so powerful.
    Write your review.:mounty:
  2. kustomizingkid
    kustomizingkid Nuba Guru
    The problem is that for detailing super high power isn't needed... and isn't even ideal...
    I have used pressure washer on heavy equipment that took decals right off... do you want to be blasting a BMW and have the badges falling off?
  3. 911Fanatic
    For the average detailer, around 2 gallons per minute (gpm) and 1500psi is adequate for most detailing jobs.
  4. supercharged
    1750 PSI Karcher here.
  5. slanguage
    i have a 2 gpm 2100 psi gas powered one :D
  6. rwisejr
    rwisejr DB Forum Supporter
    Camspray 1500A - Electric 1450 PSI its a beast . Thats what Phil @ Detailers Domain sells and uses.
  7. richy
    I've got a Karcher 1800 and it's great. My old one was a 1500. It was ok..this one's better, but I don't need anything more powerful than what I have now.
  8. Julian_B
    Julian_B Any Rag Vehicle Washer
    I've been really happy with my little Karcher K-2.45 1400psi model. Just enough for what i need to do. my $0.02
  9. 911Fanatic
    I bought a little 1500psi, 1.5 gpm electric from Home Depot on sale. I had to as it was only $49. The wand sucks but the little guy works great. I don't how long it'll last but it was only $49!
  10. willjco
    willjco DB Forum Supporter
    I have a 2100psi task force pressure washer i got at lowes....I love mine. It all really depends on how much $$$$ you want to shell out if you have the money i would go with the camspray but the cheep one work fine but they dont last as long
