Pad recommendations for the flex?
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by m4gician, Jan 10, 2008.
  1. m4gician
    m4gician Birth of a Detailer
    Hey guys,
    My question is two parts:
    1) my lc ccs pads and flat pads are what I have left over from the good old PC/UDM. Are those ample? Or should I look at purchasing some sonus pads from eshine?
    2) I have menz 83 and 106ff, so which pad would be optimal?
    All my pads are 6.5 inch, I do however had a couple of 5.5 orange and white pads.
  2. jshillin
    jshillin Birth of a Detailer
    I think you'll be fine with the LC pads. I just used a blue CCS pad on my flex the other day, worked great with PO85RD.
  3. eShine
    eShine Guest
    You should definately buy more from us :D
    1)The pad that came with the UDM are made by Lake Country, so are the Sonus pads. I like the Sonus pads because they are smaller (6") and work better on a PC or UDM. For a Flex definately go with the 6.5" CCS.
    2)I use Orange with 83 and follow up with either white/black using the 106ff, works for me 99% of the time.
  4. JLs Detailing
    Chris the white Sonus pads I got from you are the absolute BEST as far as I am concerned if you have the new 5.5" bp for the Flex. I like them a lot better than the 6.5" LC CCS pads. The only problem is I should have bought more of them. Those Sonus pads are easy to control and I don't think I use as much product with them either.
  5. Nica
    See why I purchased a case of each :chest:
    But yes I agree with Wolf, the sonus pads are great. Good, size and are easy to work with and I too have noticed that once the pad is saturated you use less products, something that the Meg's pad didn't do. I mean no matter how much product I use with the Meg's pads they just wont saturate :confused: not sure if it's just me but that's what I noticed.
  6. Carn
    Carn Welcome to Detailing
    So are the Sonus 6" pads the ones to go for with the newer 5.5" backing plate ?
    Was hoping the LC 6.5" pads would still work with the Flex as they have a nice range of different grade pads.....Would the 6" 3M pads also work with the Flex ?
  7. vrwm
    vrwm Jedi Nuba
    Carn, All the pads you posted will work with the Flex. If you just recently ordered one you should have the new 5.5 in backing plate. I think the only pads that aren't compatible would be the Edge pads, because they need a special adapter, and the 4 in pads. The 4in pads will stick on, but I wouldn't recommend it. If I were you I would either go for the LC 5.5 or 6.5 Pads.
  8. Carn
    Thanks VRM, trying to do as much research as possible before jumping in
  9. OrngeZ
    OrngeZ Birth of a Detailer
    if you like the sonus pads the CG MPT pads are "very" similar...hehe
  10. Carn
  11. vrwm
    vrwm Jedi Nuba
    DD carries some PORTER CABLES & ACC. I haven't tried 5 1/4 so I'm not sure how well they fit on the backing plate.
  12. the edge
    the edge Virgin Detailer
    are you sure?
    YouTube - Edge 2000 Flex Conversion!!!!!
  13. P1et
    What makes the Sonus pads better than the Lake Country pads?
  14. Nica
    My opinion is the thickness of the pads, Sonus has a different feel to it and it feels as though you have two LC pads...but that's just my opinion.
  15. sneek
    sneek Nuba Guru
    The Sonus pads from eshine are SUPERB
  16. sneek
    sneek Nuba Guru
  17. P1et
    Does the pad skip less when comparing the Sonus pads vs. the Lake Country pads? My white ones like to skip if you're not holding it down...
  18. vrwm
    vrwm Jedi Nuba
    Looks good:thumb:, I guess I have to add it to the "to buy"list. I never tried edge pads yet, but in time I will. Is the adapter out yet?
  19. dsms
    dsms DB Forum Supporter
    I am waiting for that edge adapter for the Flex. Also wondering if anyone has used the 6.5inch LC wool pad with their flex yet?
