Ferrari wheel help ASAP!
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by bigfoot, Aug 31, 2009.
  1. bigfoot
    bigfoot Jedi Nuba
    Need some help to remove some rubber stuck on the wheel of this Ferrari F430 Scuderia. Here are some pics.
    What can I use to remove the rubber off the wheel WITHOUT damaging it?
    Thanks
  2. billyblooshoes
    hmm. no experience with ferraris here, so i dont wanna risk telling you the wrong thing.
    but side not, why the HELL would they put the wheel weight on the lip of those wheels?!?! thats just insane.
  3. Dsoto87
    Dsoto87 Jedi Nuba
    Wow, why WOULD they put the weights there?????
    Not knowing the finish on those wheels, I would try to heat it up with a heat gun or blow dryer, than try and scrape it off with a plastic razor/credit card
  4. dadswrld
    dadswrld Birth of a Detailer
    I would be looking for Bob or Dsms (the dynamic duo) to help me out on this one, seeing they've had their hands on a few.
    Good luck.
  5. slanguage
    :agree:
  6. 911Fanatic
    Use some tar and adhesive remover. The trick with most of these products is letting them dwell. Spray it on, let it sit and repeat until its softened it enough that it wipes off. Just talked to Bob at Auto Concierge for you. He mentioned Tarminator and said that would probably do it for you. :)
  7. Darkstar752
    Darkstar752 Horizon Detailing
    Tarminator and some light heat should do the trick.
  8. agpatel
    agpatel OD On Detailing
    Because of the clearance between the caliper and the wheel itself is tight, if you put a wheel weight there you run a high risk of it hitting the caliper.
    Tar remover will and should work. They are clear coated wheels and should have no issue like Ken said.
  9. Aesop
    Aesop Jedi Nuba
    Mine are weighted on the back lip.
  10. agpatel
    It depends on were the weights need to be placed, sometimes the weight needs to be on the back side and sometime it needs to be by the spokes. It just depends on how the rim/wheel is balanced and were the weight needs to be placed to balance out the forces when spinning.
  11. slanguage
    offsets/design/size can also play a factor is wheel weight placement.
  12. Got Wax
    Got Wax Banned
    Heat and adhesive remover. Easy fix. It's a wheel. The fact that it is on a Ferrari or whatever, makes no difference.
    Just sayin'!!
    Andy
  13. Solidsnake
    Solidsnake Jedi Nuba
    Spray Tarminator on it, let it settle in, agitate with a brush then try claying it?
  14. JohnyB
    JohnyB Birth of a Detailer
    Sounds scary but you can use a plastic razor to aid in the removel with the sugested advice above. let use know how it turns out bud.
  15. WhataVUE
    WhataVUE Virgin Detailer
    I cant see that being a wheel weight. Is the car a track car? I know some of these babies are driven before delivery. Just treat it as you would another wheel with rubber. Maybe a hairdryer and a finger nail or some tar remover.
  16. agpatel
    All Ferrari's are driven on the Ferrari test track to make sure everything is up to order a few times. But like everyone has said treat it like any other wheel.
  17. bigfoot
    bigfoot Jedi Nuba
    Thank you all, guys! I know I should treat it like every other wheel, but being an expensive wheel, I want to take all the precautions to make sure I do it right.
    Thanks again!
  18. agpatel
    Dont blame you, might as well ask if you have the time to ask before you have to work on it. Better safe than sorry.
  19. bentley147
    bentley147 Jedi Nuba
    get some oven bake from the supermarket ..spray on there let it sit for about 5 mins..... then take it off
  20. Auto Concierge
    Auto Concierge DB Pro Supporter
    Uhmmmm no....................................................... do you know what is oven cleaner which allows it to work without agitation:gasp:
